Cap'n, I sent you a PM on this.
I agree with the others ... I'd go at least 4,000 - 4,500 before doing a change. The motor's long since broken in and the vehicle is driven often ... dumping a $5+ per quart motor oil after just 3,000 miles is kinda wasteful.
I wouldn't worry about a ~2ppm 'spike' in copper. 1-2 ppm of ANYTHING should not be cause for alarm. The sampling method and these $20 tests are just not that precise.
Speaking of the copper, does anyone have any idea where it's coming from? with no accompanying lead, it doesn't appear to be bearings ... or is the material in this motor different? And with no accompanying tin (not even a trace in any sample to date) it doesn't appear to be brass or bronze. Very odd.
