Originally Posted By: moribundman
It looks like comparing the speed of SD and SDHC cards may be difficult. In the case of SD cards, the speed is maximum speed, in the case of SDHC cards it is a minimum sustained data transfer speed.
Nope, all advertised speed are maximum speed, and all "speed class" rating are the minimum speed guaranteed. Like the HP curve of your car, the dealer advertise the maximum but you may be using the minimum at any given time.
The only difference between SD and SDHC is the addressing mode. SD uses byte addressing and maxed out at 4GB, SDHC uses sector addressing and maxed out at a much higher number (higher than what you will reasonably use any time soon). Other than that SDHC obsoleted some unrealistic spec like write protect of certain regions of the card, etc.
Components between the 2 are identical: same controller, same memory. You will find both good and bad cards in both categories.
I agree with the quality control of our MP3 players. I personally returned a few myself, but the cards are much better build and developed. Still, if you don't like it, there are other good cards out there.
