A while back I got a new riser stem and handlebar for my mountain bike because I wanted to change from 31.8 to 25.4. After I changed the bar and stem, I forgot which side the cable routing should go for the front derailer. I'm referring to cable housing that connects from the shifter to the frame. I'm not sure if it should go to the left or right side of the frame. The bike has the 3 cables that run parallel on top of the frame and the front shifter uses the middle of the 3.
I'll try and take a pic and post it up later its hard to describe in words. Any suggestions appreciated, thanks.
