G gnm Joined Sep 4, 2008 Messages 2 Location Florida, USA Oct 10, 2008 #1 Anyone know where I could get a clay base lube for slack adjusters on an RV? The manual calls for that and can't find it locally. Thanks!
D Diesel_Clatter Joined May 11, 2006 Messages 152 Location Ohio Oct 10, 2008 #2 A source I like for stuff like this. http://www.mcmaster.com They have quite a few varieties of bentone-clay thickened grease.
M moribundman Joined Jun 2, 2003 Messages 23,591 Oct 11, 2008 #3 Plastilube is made with bentonite (clay): PDF I use Plastilube for all sorts of squeaky things. It lubes well, lasts pretty long, doesn't melt, and it tolerates some moisture.
M mpersell Joined Dec 12, 2006 Messages 341 Location Texas Oct 11, 2008 #4 Schaeffer has several bentone thickened clay based greases.
M moribundman Joined Jun 2, 2003 Messages 23,591 Oct 12, 2008 #5 Originally Posted By: mpersell Schaeffer has several bentone thickened clay based greases. What's the minimum order? For motor oil that had a minimum order limit that made ordering from them unreasonable for a "micro consumer" like me.
salesrep Joined Aug 22, 2003 Messages 3,653 Location lllinois Oct 14, 2008 #6 Our 248 and 260 would be your choices with clay based. 30 tubes to a case.
M moribundman Joined Jun 2, 2003 Messages 23,591 Oct 15, 2008 #7 Originally Posted By: salesrep Our 248 and 260 would be your choices with clay based. 30 tubes to a case. What am I going to do with a whole case?
salesrep Joined Aug 22, 2003 Messages 3,653 Location lllinois Oct 15, 2008 #8 Mori if you got some high temp situations with your mining, asphalt plant or heavy equipment needs this grease would be a great fit. http://www.schaefferoil.com/datapdf/248.pdf
M moribundman Joined Jun 2, 2003 Messages 23,591 Oct 15, 2008 #9 I already lubed my Komatsu wheel loader.
