I have a Chevy Corvette, with stroked and bored out LT1 engine. The clearances arent loose, or tight per sey. But is there a general rule of thumb for oil viscosity for clearances within bearings etc.
My engine build was many years ago, and I was never given a recommendation other than Mobil 1 10w30 will be fine. Not a confident answer, just an answer.
I just re ringed it, and clearances havent changed but I have been using Shell Rotella synthetic, at Wal Mart. My oil pressure is 45 psi at 180 degree oil temp. I have a high volume regular pressure GM oil pump in there from Mellings. The pressure is a little high, but I bypassed the oil filter bypass to ensure oil filtration (WIX) continuously.
What oil would you recommend? Shell fine? No oil analsys yet.
Or should I go a higher quality oil, aka more expensive with higher base stock.
Thanks, Steve
Thanks, Steve
