I have a feeling that you want to use the longer 16lb bypass valved filter on one of the lower filter's spec'd vehicles.
Taking the lower spec'd filter's number and x'ref'ing to Puro ..you get
L14459
Height: 2.95
Type of Filter: Spin-on
O.D.: 3.15
Relief Valve P.S.I.:
12-15
Anti-Drain Back Valve: Yes
Threads: M20x1.5
Going the other way
L24458 (discontinued)
Threads: M20x1.5-6H
12-15
Height: 3.94
O.D.: 3.15
To Donaldson....
51568 WIX P555522 LUBE FILTER
51334 WIX P550162 LUBE SPIN-ON
L14459 PUROLATOR P550162 LUBE SPIN-ON
L24458 PUROLATOR P552849 SPIN-ON LUBE FILTER
P555522
Lube Filters Product Attributes
A - OD (Inches): 3.12
B - Thread Size (Inches): M20 X 1.5
C - Length (Inches): 3.87
D - Gasket OD (Inches): 2.45
E - Gasket ID (Inches): 2.15
Relief Valve Setting (PSI): 11-17
Anti Drain Valve (Y/N): Yes
Product Type Description: LUBE SPIN-ON FULL FLOW
Primary Application: THERMOKING 11.5522, J.DEERE,
Primary Application 2: YANMAR
P550162
A - OD (Inches): 3.18
C - Length (Inches): 3.39
D - Gasket OD (Inches): 2.5
E - Gasket ID (Inches): 2.11
Primary Application: Kubota 70000-15241
P552849
A - OD (Inches): 2.96
C - Length (Inches): 3.4
D - Gasket OD (Inches): 2.7
E - Gasket ID (Inches): 2.33
Relief Valve Setting (PSI): 11 - 17
Primary Application: FORD, MAZDA
Here's a different one when you "back feed" the Donaldson numbers back into Wix again..
P555522 & P552849
Part Number: 51347
UPC Number: 765809513471
Principal Application: Ford Courier (72-82), Hyster, Komatsu, Merc. Bobcat (75-79), Pinto (75-79), Thermo-King, Yanmar Excavators
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.828
Outer Diameter Top: 2.921
Outer Diameter Bottom: Closed
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 8-11
Burst Pressure-PSI: 325
Max Flow Rate: 9-11 GPM
Nominal Micron Rating: 20
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.734 2.430 0.226
..which ..put into Purolator
P555522&P552849 to L20073
Threads: M20x1.5-6H
Height: 4.74
Relief Valve P.S.I.: 12-15
O.D.: 2.98
P550162 to L14459
Height: 2.95
O.D.: 3.15
Threads: M20x1.5
I think that's as many ways as I can skin this cat
