UOA's start @ 10 K
1 Motul Specific -- oil & filter
2 Motul Specific -- oil
3 Amsoil AFL ------ oil & filter
4 VW LL III -------- oil - DRF count this OCI
5 VW LL III -------- oil & filter - oil pan heated < 70F
6 VW LL III -------- oil & filter - oil pan heated < 70F
Ave mpg ---- 42.5 -- 43.0 --- 43.0 --- 43.0 ---- 43.2 --- 43.1
Hours / oil --- 132 --- 131 ---- 100 --– 103 ---- 150 ----- 184
Miles / oil -- 5009 -- 5000 -- 4000 -- 4000 --- 6021 --- 7001
Fe - 24 - 24 - 22 – 22 -- 15 - 17
Cr --- 1 –- 1 -– 0 --- 0 ---- 0 -- 0
Ni --- 1 –- 1 –- 0 --- 0 ---- 0 -- 0
Al --- 4 -– 4 –- 3 --- 2 ---- 4 -- 4
Cu -- 3 -– 3 -– 2 --- 3 ---- 4 -- 4
Pb -- 2 -– 2 -– 2 --- 2 ---- 3 -- 6
Sn – 0 –- 0 –- 1 --- 0 ---- 1 -- 1
Si --- 4 –- 6 -– 5 --- 6 ---- 3 -- 4
Na - 15 – 9 -– 7 --- 8 ---- 3 -- 2
K ---- 1 -– 2 -– 1 --- 2 ---- 1 -- 3
Fuel Vol --- < .5% - Soot Vol --- Vis 100C --- 13.4 –- 13.2 --- 13.1 –- 11.5 --- 11.5
TBN ----------- N/A --- N/A ---- N/A --- 4.88 --- N/A
All these oils were driven under the same conditions and fuel was purchased in 250 gallon batches. This motor is wearing very well for a notorious PD. Now its time to show that a PD motor can use a CJ4 505.01 oil made in the USA and cut cost by 50%. It came down to three oils. I felt the best synthetic CJ4 5w40 oils were, Amsoil DEO, Mobil Delvac 1 ESP, and Schaeffer S9000. Each oil had specific advantages. S9000 was the least expensive and Schaeffer supports the use of this oil in a VW PD motor, Amsoil and Mobil would not. 505.01 is posted clearly on the container, in their product brochure and if you write them they will tell you use with confidence. So on 8/20/08 I changed my oil to S9000. It took a 100 miles but the engine got real quiet. As far as MPG I expect to lose less than 1 mpg going from a 11.5 cSt to 14.5. I had my first sign of soot this OCI of .1% @ 7k interval. A DG by-pass filter may be in my future. I was going to try Total Ineo 504/507 but the price was just crazy @ 11.25 per litre shipped. I have no worries at all about my engine but the DMF "dual mass flywheel" does worry me. I will post the VOA of this batch of S9000 in a week or so. There are 3 maybe 4 PD engines joining me their next OC. One PD motor is already on their 2nd OCI of S90000. The first UOA was excellent, posted here at bitog, and the 2nd UOA coming soon. Its unfortunate it may not be CJ4 as the additive counts reflect CI4+. The seller told them it was CJ4 but the UOA does not reflect that and they had already tossed the container. I will run a minimum of 3 OCI's. If the oils performance is good when compared to similar engines using 505.01 oils then I have found my 1 oil solution for all my diesels.
