- Joined
- Jun 2, 2003
- Messages
- 23,591
I had installed a nifty application (Xournal) that worked flawlessly on my Nokia N800 internet tablet. I was prompted to update it, and things went bad. Very bad. The guy who developed the program made the update available without warning to "those people" (like me, who are clueless):
Quote:
Today I've uploaded an alpha version of Xournal (packaged for diablo) on the maemo extras-devel repository. Thus, those people got the notification of an update available and went straight to the Application Manager in order to update.
I see here two mistakes:
1) they should have not installed the -devel repository (unless they knew what they were doing)
2) the Application Manager should TELL from WHERE the package is coming from
However, the next release of Xournal HAS NOT YET been released.
And I strongly suggest, whoever has the maemo extras-devel repo installed, to NOT update to the Diablo version yet.
And then he stated:
Quote:
WARNING: Installing Xournal from this install file will add either "maemo Extras (chinook)" and "maemo Extras Devel (chinook)" repositories. I STRONGLY suggest you to remove the "Devel" one after Xournal has been installed.
This install file should work on Diablo too. If you're running Diablo, after Xournal has been installed, disable both Chinook catalogues!
Anyway, I am running Diabolo and obviously I should not have updated the program. Since there was no warning, it's too late now. I found the Extras Devel repository in the Applications catalog and deleted it. I found only ONE Chinook catalog.
Anyway, I can't get the program to launch, so I want to remove it COMPLETELY. In the Application Catalog, when I check what I need to remove I find a list of "application packages." Will all those be uninstalled automatically when I uninstall the program, or do I have to hunt them down one by one? If the latter is the case, where do I find them?
The Application Manager let's me uninstall Xournal (0.4.2.1-1diabolo2), but it's only 0.8 MB small, versus the supposed 6.7 MB total. That's why I'm not sure if all Xournal "components" will be uninstalled.
And then he stated:
