I went shooting recently and I decided to try Shooter's Choice grease which I happened to find in a Big R Store. I also did a second test with BreakFree.
The Shooter's Choice grease is great! My Glock really operated well with it. So far that is the first time I have tried the Shooter's Choice but I am very impressed. This grease may be what I move to. I will need to do more testing to make sure.
I have decided to eliminate BreakFree. If you remember my post a while back when I tested BreakFree I mentioned that there were tiny pieces of what appeared to be brass from the cartridge cases in the interior of the gun. Well, this happened again and it happens only with the BreakFree. And I used a higher quality, different ammunition. I have decided that I really, really dislike BreakFree. The Birchwood Casey gun oil was much better.
A guy who used to shoot .45s in competition told me he used to use Shooter's Choice grease. And now he uses some Lubriplate grease that is used mainly for automotive door hindges.
Well, I am not going searching all over the place to find that Lubriplate grease. The Shooter's Choice grease is really excellent as far as I can tell so far. As long as it is available whenever I need it at the Big R Store. If they were out when I needed it I would probably use the Birchwood Casey gun oil.
