2006 6.0L w/almost 36,000 miles on engine.
My last two oil changes have shown higher lead - 7 ppm. The previous numbers had all been 2 ppm. This last oil change, I had two separate labs run the analysis just to see if the numbers were consistent. They were - 7 ppm and 6 ppm.
Is 7 ppm lead indicative of a developing bearing problem or is it jst the high side of normal? If so, is there anything to do other than "keep an eye on it". What would be considered an "action level" where it should be taken in to be looked at?
Oil - Schaeffer 9000 5W-40
Oil Change Date 9/11/2008
Miles on Truck 34690
Miles on Oil 4613
Oil change # 9th
Aluminum........3.......1
Chromium........1.......1
Iron............26......24
Copper..........3.......3
Lead............7.......6
Tin.............0.......0
Molybdenum......283.....259
Nickel..........0.......0
Manganese.......0.......0
Silver..........0.......0
Titanium........0.......0
Potassium.......3.......1
Boron...........7.......3
Silicon.........7.......9
Sodium..........5.......5
Calcuim.........3689....3400
Magnesium.......8.......10
Phosphorous.....1312....1173
Zinc............1453....1343
Barium..........0.......0
Vanadium................0
Antimony................41
SUS vis at 210 F 69.6
cSt at 100 C....12.85...13
Flashpoint......390
Fuel............2....... Antifreeze......0
Water...........0....... Insolubles......0.2.....
Miles on Oil 4613
Oil change # 9th
Flashpoint......390
