97tbird yes of course it is a much better reg cleaner than anything used to date and you can compact the registry as well. Pretty scary the first time you run it after using Reg Mechanic and others as it found over 500 spurious/duplicate entries first time I ran it. Required two scans to fully clean the registry. My XP SP2 PC has never given a problem after years of use and OS is as it came from HP compaq (D530 SFF)
