If you want the message to go away(from Microsoft):
To turn off this error message, you must follow these steps:
1. Open Device Manager. To do this, click Start, click Run, type devmgmt.msc in the Run window, and then click OK.
2. Expand the Universal Serial Bus Controllers section at the bottom of the device manager window. Locate and then double-click a host controller that has either the word Universal or the word Open in the title.
3. In the properties dialog box, click the Advanced tab, and then select the Don't tell me about USB errors check box.
Note If you turn off this option, all other USB error messages are also turned off.
As was said above, you can get 4+1 USB 2.0 cards for $10.
