OVERKILL
$100 Site Donor 2021
This is the Donaldson P169071 spin-on oil filter for Ford applications, as well as many others. This filter contains the Synteq filter media, which they license to Amsoil for use in the EaO filters.
Specs:
Lube Filters Product Attributes
A - OD (Inches): 3.67
B - Thread Size (Inches): 3/4-16
C - Length (Inches): 5.32
D - Gasket OD (Inches): 2.85
E - Gasket ID (Inches): 2.47
Relief Valve Setting (PSI): 8-11
Product Type Description: LUBE SPIN-ON FULL FLOW
Primary Application: HIGH EFFICIENCY VERSION OF
Primary Application 2: P550008
Application Note: SYNTEQ Media
Packaged Dimensions
Country of Origin US
Gross Height in Inches 6.5
Gross Length in Inches 4
Gross Weight in Pounds 1.15
Pieces Per Pallet 54
Gross Width in Inches 4
Observations:
Looks like a basic 302 filter. It is quite heavy. Has a Parker anti-drainback valve, which does not appear to be silicone.
The centre tube has good perforation with the media and it's protective screen visible through it. It also has a "pattern" all over it.
The bypass valve on the bottom is unlike the Purolator PureONE, K&N and AC Delco filters I have previously disassembled. I will know more when I take one apart.
And the pictures:
Specs:
Packaged Dimensions
Observations:
And the pictures:
