I just had a thought the other day.
The status quo seems to be to add the cleaner on the last tank prior to an OC, to drain the oil after using the cleaner.
THe injector bottle usually says AFTER the OC.
In a sound engine, the fuel system would be generally isolated from the lubricant to some degree (otherwise you have a fuel dilution problem?) so wouldn't it make sense that it DOESN'T matter when you add the cleaner?
That is, if you are concerned about the FI cleaner contaminating the oil you have a much more serious fuel dilution problem...
Any crud burnt off in the fuel system or cylinder would be combusted and exhausted and not end up in the oil?
Any thoughts. I may be totally wrong.
