Let me get out of the way first that this is mainly a matter of curiousity rather than practical need. But I'm wondering why the Amsoil oil product lookup guide seems to select the wrong oil for BMW engines.
In my particular case it's an E46 with an M52TU engine, but I get the same results selecting for a M54 engine.
The Amsoil product lookup guide advises three oils:
SAE 0W-30 Synthetic Signature Series Oil (SSO)- ACEA A5, Kv100=10.3
SAE 5W-30 Synthetic Motor Oil (ASL) - ACEA A5, Kv100=10.7
SAE 5W-30 XL Synthetic Motor Oil (XLF) - ACEA A1,Kv100=10.5
In contrast, every BMW approved oil is an ACEA A3 and the lowest Kv100 I've seen on an approved oil is 11.3.
Now if you to the detailed product specs for each of the above listed Amsoil oils, none of them state or imply suitability for BMW's.
Amsoil does have one oil that is an ACEA A3, has a Kv100 in the range of known BMW approved oils, and is listed as suitably equivalent to the BMW LL-04 spec and that is the Euro 5W-40 (AFL).
But you sure wouldn't know that from the product look-up guide.
So is the recommendation generator just a rather simplistic one only spitting out the 0W-30 and 5W-30 oils, or is there actually some technically logical reason to recommend those three oils but not the AFL for BMWs?
