I thought about buying an Ingersoll-Rand Quiet series impact wrench and the appropriate air compressor, but after some research, I discovered that it would cost me around $1000 total for a setup that is not very portable. So, someone recommended that I consider a high-end cordless impact wrench instead. I found a cordless impact wrench that would give me 400 ft-lbs (620 ft-lbs for breakaway) of torque for around $500. Here's a link to it:
http://buy1.snapon.com/catalog/item.asp?...ore&dir=catalog
Since I only plan to use the impact wrench to rotate tires, do timing belts and suspensions, is this impact wrench up to the task?? I do not mind spending more money if it will buy me a more powerful and longer lasting tool. Are there other cordless impact wrenches that are more powerful and more durable in the same price range? Or should I just stick with a good 'ol compressed air setup?
Thanks!
Thanks!
