Magnatec 5w30 - Push Mower
by SavagePatch
05/06/16 11:31 AM
RAM 1500 EcoDiesel filter
by pb379
05/06/16 09:14 AM
Motul 8100 X-Cess 5W/40 11,568Miles BMW335i
by strongmad
05/06/16 08:52 AM
Lawn Tractor Utility Upgrade
by bigdreama
05/06/16 08:50 AM
Help with iphone on the home network
by buck91
05/06/16 06:45 AM
2003 lesabre battery change back seat type
by snake123
05/06/16 05:43 AM
Penrite 0w-16
by toyota62
05/06/16 03:31 AM
Land Cruiser stuck in mud, rescued by hemi Jeep
by Shannow
05/06/16 02:53 AM
GM to test self-driving taxis
by xfactor9
05/06/16 01:09 AM
Resurfacing Brake Rotors
by The Critic
05/06/16 12:02 AM
Largest M1 filter for Jeep 4.0
by ARMY_Guy
05/05/16 10:50 PM
Mobil 1 or Castrol edge?
by sky06
05/05/16 09:48 PM
waldawg, Defcon, drivingaford, funkyheff, Ralph62
57814 Registered Users
87 registered (15SilvyEcotec, AirgunSavant, Alfred_B, Al, 901Memphis, ARCOgraphite, 6 invisible), 0 Guests and 0 Spiders online.
57814 Members
66 Forums
248543 Topics
Page 1 of 7 1 2 3 4 5 6 7 >
#1231182 - 09/06/08 04:11 PM Synchromesh Manual Transmission Lubricants
MolaKule Offline
Loc: Iowegia - USA
White Paper - Synchromesh Manual Transmission Lubricants
Since there has been so much discussion and questions about MTL's, here is a white paper that I hope answers some questions.
 Quote:
Most GL5 differential and GL4 Manual Transmission oils contain sulfur-phosphorous EP packages. GL4 does NOT refer to any specific viscosity, but it refers to a level of AW/EP protection for the gearing and bearings in a transmission. GL4-rated oils contain about 40% to 60% of the EP additives that GL5 oils contain.
Both differential and manual transmission fluids use chemical compounds that subdue or inhibit the corrosive effects of sulfur and phosphorous such as calcium, magnesium, boron, potassium or other basic compounds. Emulsifiers, corrosion and rust inhibitors also are included to do their respective jobs.
GL5 differential lubes use friction modifiers to reduce mechanical and fluid friction and add some anti-shudder friction modifier for limited slip, both very different chemical compounds.
Manual Transmission fluids use a different friction modifier for synchro engagement, a modifier that does NOT contain the same Friction Modifier chemicals as differential lubes.
Most manual transmission "specific" fluids (GL4) contain about 40% to 60% of the EP additive of differential lubes (GL5) with inactive or buffered sulphurs. GL4 has come to infer a gear lube with the above percentages of EP additive. The exception of course is ATF fluid used in some of the newer transmissions.
Therefore, both lubes contain the same EP additives, just in different strengths or additive ratios.
Ever since the synchromesh-type fluids appeared on the scene (such as the GM Synchromesh fluid), drivers have had better shifting due to better synchro engagement, attributed to the specialized friction modifier used in these lubes. This specialized friction modifier is better for metallic and composite synchros in terms of shifting and life.
Manual Transmission fluids use a different friction modifier specifically designed for synchro engagement, a modifier that does NOT contain the same chemical compounds as do differential lubes.
A synchromesh fluid usually refers to a specialized fluid that contains special friction modification additives for transmissions that use mechanical synchronizer assemblies; those synchronizer assemblies may be made of carbon fiber composites, sintered metal.
You also have to consider the viscosity of the fluid that the transmission was designed for. The spectrum now ranges from ATF to 75W90 viscosities and therefore a synchromesh GL4 Manual Transmission Lubricant (MTL) can be any viscosity from 7.0 cSt (ATF equivalent viscosity) to a 75W90 type viscosity of approx. 14.5 cSt, and contains special friction modification additives for synchronizer assembly engagement.
brass/bronze, or steel-steel materials.
Current MTL GL4 viscosites are:
1. ATF Series - Type; 6.5 to 8.5 cSt (Equivalent ATF viscosity; Note: ATF additive package is weak compared to most GL 4's)
2. Synchromesh Series -Type; 9.3 - 9.5 cSt (such as Amsoils MTF, Texaco's MTL, Pennzoil's Synchromesh, GM and Chrysler's Synchromesh)
3. 75W85 Series-Type; 9.8 to 11.5 cSt ( Redline's MTL, RP's Synchromax LT, Nissan's MTL, Honda MTL, Castrol Syntorq LT)
4. 75W90 Series-Type; 12.8 to 14.5 cSt (Amsoil's MTG, Redline's MT-90).
MTL specific lubes we're developed for manual tranny's and transaxles, and not for differentials or industrial gear boxes. A differential lube may not kill your tranny, but it is not the optimum lube for it. A diffy 75W90 (GL5) usually has a higher viscosity than does an mtl in the same advertized weight.
Edited by MolaKule (09/06/08 04:21 PM)
Stop worrying about what you have to lose and start focusing on what you have to gain. smile
#1231196 - 09/06/08 04:54 PM Re: Synchromesh Manual Transmission Lubricants [Re: MolaKule]
simple_gifts Offline
Loc: Middlesex County CT
Great summary for people like myself, Thank you.
2003 Echo >390K miles; Showing its age.
2006 B2300;105K;ALM
Please conserve paper; it is not like it grows on trees.
#1231208 - 09/06/08 05:18 PM Re: Synchromesh Manual Transmission Lubricants [Re: MolaKule]
Quattro Pete Offline
Loc: Great Lakes
Why is that? Do these fluids not require stronger additive packages or is the low viscosity index preventing the introduction of stronger additive packages?
FYI... my car's manual tranny requires an ATF-like fluid, so I'm using RP Synchromax in it...
http://www.royalpurple.com/prod-pdfs/synchromax-ps.pdf
'02 530i (PPE 5W-40)
'15 Q5 3.0T (Edge 5W-40)
#1231225 - 09/06/08 06:03 PM Re: Synchromesh Manual Transmission Lubricants [Re: simple_gifts]
MolaKule Offline
Loc: Iowegia - USA
 Quote:
Synchromesh Manual Transmission lubes we're developed specifically for manual transmissions and transaxles, and not for differentials or industrial gear boxes.
A synchromesh fluid usually refers to a specialized fluid that contains special friction modification additives for transmissions that use mechanical synchronizer assemblies; those synchronizer assemblies may be made of carbon fiber composites, sintered metal, brass/bronze, or steel-steel materials.
Most Differential and Manual Transmission oils contain sulfur-phosphorous EP packages. GL4-rated oils usually contain about 40% to 60% of the amount of Differential lubricant EP’s. Therefore, both MT and Differential lubes contain the same EP additives, just in different strengths or additive ratios.
GL4 does NOT refer to any specific viscosity, but it refers to a level of AW/EP protection for the gearing and bearings in a transmission, so GL4 has come to infer a gear lube with the above percentages of EP additive. The exception of course is ATF fluid used in some of the newer transmissions.
Differential lubes use friction modifiers to reduce mechanical and fluid friction and add some anti-shudder friction modifier for limited slip; both very different chemical compounds.
Current MTL GL4 viscosities are:
1. ATF viscosity Series; 6.5 to 8.5 cSt (Equivalent ATF viscosity; Note: ATF additive package is weak compared to most GL4's)
2. Synchromesh viscosity Series; 9.3 - 9.6 cSt (such as Amsoils MTF, Texaco's MTL, Pennzoil's Synchromesh, GM and Chrysler's Synchromesh)
3. 75W85 viscosity Series; 9.8 to 11.5 cSt ( Redline's MTL, RP's Synchromax LT, Nissan's MTL, Honda MTL, Castrol Syntorq LT)
4. 75W90 viscosity Series; 12.8 to 14.5 cSt (Amsoil's MTG, Redline's MT-90).
A differential lube may not kill your manual transmission in your light truck or car, but it is not the optimum lube for it. A differential 75W90 (GL5) lubricant usually has a higher viscosity than does an mtl in the same advertised weight.
Many if not most GL5 fluids rated for differentials may also be rated as MT-1. Some manufacturers, such as Amsoil®, state the following:
“Recommended for use in differentials, manual transmissions and other gear applications requiring any of the following specifications: API GL-5, MT-1, MIL-PRF-2105E, Dana SHAES 234 (Formerly Eaton PS-037), Mack GO-J, or the differential (hypoid) gear oil specifications from all domestic and foreign manufacturers such as GM, Ford and Daimler Chrysler. Can also be used in axles where an API GL-4 lubricant is recommended.”
This MT-1 rating refers to use in heavy duty truck transmissions, and as such, does NOT necessarily mean that this fluid will function properly in a light truck or car synchromesh transmission.
Edited by MolaKule (09/06/08 06:06 PM)
#1231228 - 09/06/08 06:14 PM Re: Synchromesh Manual Transmission Lubricants [Re: MolaKule]
MolaKule Offline
Loc: Iowegia - USA
ATF fluids contain a specific additive package for Automatic Transmissions, and not for manual transmissions. Most ATF specifications for use in mtl's, IMHO, were to improve cold weather shifting, and not to improve wear.
Look at the VOA's for clean ATF fluids and compare to clean MTL analysis for example. There is a big difference in the AW/EP additive levels between the two.
ATF's contain AW's, whereas mtl's and differential lubes contain
both AW's and EP agents.
Viscosity and Viscosity Indexes are two different animals.
Edited by MolaKule (09/06/08 06:22 PM)
#1234273 - 09/11/08 07:14 PM Re: Synchromesh Manual Transmission Lubricants [Re: MolaKule]
Taylor Offline
Loc: VA
so an atf viscosity series should work well in a np231? chain driven transfer case no clutches or anything just a pump. If so who makes a low visc syncromesh mtl? thanx mola
Standard Produce Co.
Serving Central VA Since 1910
#1235023 - 09/12/08 08:54 PM Re: Synchromesh Manual Transmission Lubricants [Re: Taylor]
MolaKule Offline
Loc: Iowegia - USA
Many transfer cases do use ATF, while some like Toyota, use a 75W90 weight lubricant.
As of right now, I cannot recommend any 7.0 cSt lubricant for an mtl.
#1235051 - 09/12/08 09:46 PM Re: Synchromesh Manual Transmission Lubricants [Re: MolaKule]
Taylor Offline
Loc: VA
yea its spec'd atf, after reading this i was thinking about putting in some mtl. so no one makes that visc or? would penz be to thick?
#1235064 - 09/12/08 10:26 PM Re: Synchromesh Manual Transmission Lubricants [Re: MolaKule]
Canawler Offline
Loc: York, PA
Anything wrong with Royal Purple's Synchromax? I'm currently running it in my atf spec'ed mtx as it's the only one I could find in an atf visc. (7.7cst)
Is there as much of a benefit to running an mtl in an atf spec'ed transfer case as there is to running an mtl in a mtx if the t-case has no synchros? An atf wouldn't provide the EP qualities that I assume would be good for a t-case. Would normal engine oil be any better than atf?
It's only money, you make more every day.
'05 SRT-4 / '05 Xterra / '70 Cuda / '09 Ram2500
#1235470 - 09/13/08 05:43 PM Re: Synchromesh Manual Transmission Lubricants [Re: Canawler]
MolaKule Offline
Loc: Iowegia - USA
I have no idea what the additive package or VOA might show, so as of now, I cannot comment.
#1235568 - 09/13/08 10:25 PM Re: Synchromesh Manual Transmission Lubricants [Re: MolaKule]
MolaKule Offline
Loc: Iowegia - USA
Edited by MolaKule (09/13/08 10:26 PM)
#1236554 - 09/15/08 08:12 PM Re: Synchromesh Manual Transmission Lubricants [Re: MolaKule]
Taylor Offline
Loc: VA
Is that still being made? If so its like $110/gal.......
#1236555 - 09/15/08 08:13 PM Re: Synchromesh Manual Transmission Lubricants [Re: Taylor]
Taylor Offline
Loc: VA
are you aware of any other thin MTL's?
#1250057 - 10/04/08 03:56 PM Re: Synchromesh Manual Transmission Lubricants [Re: Taylor]
Taylor Offline
Loc: VA
I dumped my ATF for some RP synchromax the other day no noticeable differences yet. NP242 (T/C)
#1391931 - 03/03/09 07:10 PM Re: Synchromesh Manual Transmission Lubricants [Re: Taylor]
wannafbody Offline
Loc: PA
I have heard of issues with RP sychromax in the T56 tranny
2000 TA WS6
