Oil pan gasket leaking, know how to replace but I need to know how to get around the transmission that is covering one side of the pan, partly over the bolts.
Car of interest is a 97 Integra automatic. Everyone that tells you how to do it online said you just remove the cover on the manual transmission, the lower exhaust manifold (B pipe), and then the bolts. Reverse for installation (plus the correct torque and sequence with a small amount of permatex at the designated area.
Anyone tried it on an auto integra?
