I bought a used Mustang motorcycle seat today for short money...was happy as a pig in poop until I went to mount it and noticed that one of the brackets was stripped out...well it was not totally stripped out when I first had it...I could screw the bolt on maybe 3/4 of the way into it before it could go no more....me using my caveman mentality figured I'll just put a ratchet on it and push it through
Bad idea
Now I have a semi smooth larger hole in the bracket that is stripped out...
Someone over on another forum mentioned having a local mechanic retap the threads...said he could probably do it quick and for short money....I'm a bit naive when it comes to this stuff so was wondering if someone could bring me up to speed on how this is accomplished...
I see a ruined bracket that needs to be replaced..others say it is an easy fix that should take no time at all
I've included some pics
Here is one to show how far I got before I tried the ratchet idea
Any insight? Easy fix or am I dead in the water?
Goose
Bad idea
Goose
