Hi
i'm planning to change the ATF fluid in my 91 Lincoln Towncar. Also i'm going to install an external cooler, but i think i'll just bypass the radiator so the fluid will be going only through this new cooler:
in addition there will be four 12cm fans, 3000rpm each attached to the cooler:
Anyway, i think i should go for some synthetic ATF because they flow better in cooler temperatures and i expect transmission to
run cooler after such mod.
I already tried that Mopar ATF+4 in my 94 Sterling 827 (honda trannsmission) and it works great, also with external cooler. (i learned about it from this forum)
So what do you think? should i use mineral dexron III or try this fully synthetic Mopar ATF+4 ?
My Towncar doesn't shift very smooth , rather kind of harsh so i won't be loosing much anyway if for example that ATF+4 adds more friction then regular dexron.
