Originally Posted By: exranger06
In 1993 the torque converter lockup and the 3-4 shift are electronically controlled. Everything else is vacuum modulated.
As I confessed earlier I probably cut class on trannys 101. Since the TC is electronically controlled what exactly is it not doing if this is in fact is the problem? It appears to be in OD each time I move the shifter out of OD into the D position. But yet when in OD it feels almost like compression braking, although slight when my foot comes off the gas. Does the TC locking up make it more like being in neutral when my foot comes off the gas?
Go easy I am trying to make up the class I missed
Thanks,
Frank D
When the torque converter locks up, it should feel like another shift. You have the 1-2 shift, the 2-3 shift, the 3-4 shift, and then the torque converter locks up. If you had a tach you would see the rpms drop when the t/c locks up.
A simple way to test to see if the torque converter is indeed engaging is at around 50 MPH, keep your foot on the gas pedal, and with your left foot - tap the brake pedal and let off. This will disengage the lockup of the torque converter. You should feel the RPMS increase.
Or another way is to get on a highway/freeway going around 55 or above. Push the gas pedal down slowly until the tranny downshifts. THEN, manual move the gear selector from overdrive to 3. You should feel another downshift. The first shift should have been the torque converter disengaging.
I went through this on my first Aerostar (87) after a rebuilt tranny. My 87 had a tach (digital gauges) and I could see when driving on the highway that my RPMS were much higher than they used to be. The original tranny shop said this was normal and nothing was wrong.
I took it to another one and they showed me these "tricks". In my case I had a bad "computer" is what they diagnosed. After replacing the computer - all was well. I traded the 87 in on my current 95 about 3 months later.
I've had very few problems with the 95,(one 02 sensor and TPS sensor) but had NOTHING BUT PROBLEMS with the 87.
