Getting low Fe readings (shedding of iron from cylinder walls,valve train,timing chain etc.)has shown that heavier oils,including the 10W-30 types,in the 4.0L engine reduces this reading.Gary has done testing with experimental 20w oil and it shows that this engine will live with that weight,but with a robust additive package being key.That oil is not for general public use.Mind you not all 4.0L engines showed improved readings with a heavier oil,but more than not.Delvac 1,Rotella,Esso XD-3 (all HDEO's) showed great single digit readings on used oil testing along with the thicker 30 weights.
