Originally Posted By: 330indy
Originally Posted By: Doug Hillary
Hi,
330indy - You should have it by now
(thanks)
I was hoping for more info on the formula of TWS10w60 and what in particular makes it so mystical and special that it is such an exclusive solution for the M engines. Can you give some more detail?
(please)
Off a German BMW forum - film strength comparison for various engine oils:
MOTUL 4100 Turbolight 10W-40 4,200 kg/cm ²
MOTUL 4100 power 15W-50 4,800 kg/cm ²
MOTUL 6100 synergy 5W-40 5,200 kg/cm ²
Castrol Formula R-S 10W-60 6,800 kg/cm ²
Castrol TWS 10W-60 17,800 kg/cm ²
MOTUL 300V Le Mans 15W-60 22,000 kg/cm ²
The Motul 300V is a pure racing oil. TWS is too, apparently, or at least more than all the rest.
Hi,
(thanks)
(please)
