I purchased a set of NAPA's Adaptive One brake pads for my Saturn. The inner and outer pads use a different material. Here's the website with more information about the pads:
http://www.adaptive-1.com/
Without further delay, here are some pictures of the pads and its packaging:
Box:
Back of the Box:
Made in China!
The Contents:
Rubber coated hardware:
Inner pad, shims are rubber-coated. Notice the red dot that identifies the pad as the outer one:
Inner pad edge codes. FF rated:
Picture of the inner pad's friction material:
Outer pad, shims are rubber-coated. Notice the blue dot that identifies the pad as the outer one:
Outer pad edge codes. Only FE rated?
Picture of the outer pad's friction material. Less white stuff? :
Box:
Back of the Box:
Made in China!
The Contents:
