Originally Posted By: wgtoys
Originally Posted By: 06VtecV6
Uh, no it's eazy to prove one oil's superiority over another.. You pour oil #1, note the gas mileage and do the UOA and then do an Auto-Rx (optional)and do the same for oil #2 and then make your conclusions.however I do agree with you on one aspect..both oils are good oils but the winner will make 1 great and another good, get it?
No, it isn't that "easy". You would need to rigorously control all of the other variables like driving conditions, environmental conditions, fuel quality and so on for your proposed "test sequence" to have any validity. Then, you would have to repeat it multiple times to see how much variation still exists. If you did your proposed test sequence three times in a row while using the same motor oil each time you would still get different results each time thanks to variables beyond the choice of motor oil.
Yeah, well I, for one have been partying-on like garth ever since switching to this oil, the memories are all you need...
