Originally Posted By: FrankN4
I don't know about all HM oils but Mobil 1 HM and Valvoline Maxlife HM are actually heavy duty oils with some extra seal conditioners. If you look at the Mobil 1 10W-30 and the Mobil 1 10W-30 HM, there is a great difference. Mobil 1 has a 40C cSt of 62.0, 100C cSt of 10.0, a HTHS of 3.14, and a ZDDP level of 800.
Mobil 1 10W-30 HM has a 40C cSt of 78.2, 100C cSt of 11.79, a HTHS of 3.66, and a ZDDP level of 1000. The HM also has elevated moly, boron, and calcium.
Mobil 1 and Valvoline both say it is perfectly safe to use their HM oils in even new engines. I think the HM may be marketing in that it provides a heavy duty PCMO in the 5W-30, 10W-30, and 10W-40 grades without being a diesel oil.
quite a difference----so if I am reading it right, what it is saying is that HM is at the higher end of the viscosity range for especially at the lower temps. Will the 0 degree starts be too cold for the 10W HM since it is that much thicker? If it's a problem, I will just stay with the 5-30 or go to the 0-30 for the winter. The truck gets it's best mileage and is quiter and doesn't use any oil with M1 5-30--that's why I'm hesitant to switch to another brand.
