JHZR2
Staff member
Hello,
THe common wall between two of my bedrooms consists of two closets. One of the closet's back wall was removed, the door taken off, and thus was a "walkway" from one room to another. The previous owners effectively used the one bedroom as a huge walk-in closet.
Well we want the bedroom back... so I need to first and foremost replace that back wall that made up the wall of the bedroom and the back of the one closet.
It was recommended by a drywall guy to use steel instead of 2x4. However, other folks Ive talked to have claimed that 2x4s are stronger. The advantage of steel seems to be that it can be installed like an erector set, and is simpler than cutting a lot of lumber.
However, the steel also seems slightly more expensive than the 2x4s at HD.
So, which is the way to go? Obviously the house is made of wood, not steel. It doesnt really matter to me.
Also, working with the steel, it was recommended to do a "butterfly" for the pieces against the walls, so that the steel had two screws going out at angles from either corner. This is odd... is that the general rule, or just for some situations, like if the new wall wasnt on top of a joist?
What is the best way to put a wall back up? Any suggestions???
Thanks,
JMH
Thanks,
JMH
