I have a 1994 Ford F-450 Service truck that's just now clicking over 75,000 miles. The truck is a WORK truck that has a fairly heavy load of tools in it. Near 14,000 Lbs gross weight.
What gear oil should I use in the Dana 80 Rear end with 4.33 gears?
Truck will do a MAX of 70 MPH and normal cruising speed is 61-63 mph and it rarely goes more than 200 Miles from its home base.
