OVERKILL
$100 Site Donor 2021
Originally Posted By: H2GURU
If Toyota had a head gasket issue, they stepped up to the plate and took care of it like a man. If you have an issue with a domestic you can just forget about it. Toyota was doing free head gaskets on vehicles with over 200,000 miles on them because they felt there was enough failures to justify the expense and protect customer relations! The only early 90s Toyo p/u you'll find that will still be any good will be a 2 wheel drive owned by a geriatric. Try your local Craigs' List.
Just like they stepped up to the plate and took care of the how many million engines affected by the sludge issue, right?
