I just used this product this weekend while drilling some 1/4" mild steel angle iron. I must say it is an impressive cutting fluid because I drilled through the angle like butter. Being a skeptic I tried it on a scrap piece of 316 stainless steel and it was almost as easy. This is some good stuff and you only need a few drops to make easy work of some normally tough to cut/drill metal. I give it an A.
