Quote:
He describes the leak as being at the top of the overflow tank.
The same effect occurs if you have a leaking hose at the fitting to the tank.
Quote:
Yesterday I found the rubber fill tube between the radiator and expansion tank unhooked, how long? I have no idea, Lord only knows how many heat cycles, could have been ten- might have been fifty, One thing I do know, my truck has not overheated- not once- in south La. heat. The coolant level in the radiator wasn't even low.
Call Ripley's or audition for the next Dos Equis commercial (j/k
Quote:
Secondly even if you remove the overflow tank and the coolant is then vented to ground on each heat cycle, it would take several if not numerous heat cycles to actually get the coolant level down to the point where the truck might overheats.
Much depends on cooling system capacity ..load...service duty cycling (stop=go=cruise, hills ..flatland ..etc.).
Quote:
Any one knowing the overflow tank is leaking would know to check coolant level everyday right?
Suppose it was full? Suppose the hose connection was the only leak?
What we're probably missing is exactly where the coolant was leaking from. Coolant recovery tanks have overflows in them. They also may have connections near the top (most that I've seen, anyway).
Now he could have already had a head gasket leak. Depending on how severe, he may initially produce bubbles into the system and push coolant out of the coolant recovery tank. As the engine warmed and cooling system pressure increased, this can be reduced and/or eliminated (it "depends").
I've just gone through this with my 91 3.0 Vulcan ..and my son's 96 2.0 SOHC Neon.
