Originally Posted By: PandaBear
Originally Posted By: unDummy
Its a ford and its not odd. I would worry about its color. For a partial ATF change, definitely shorten your change interval. Tauri transmissions don't have the reputation of being long lived.
Maybe you are not up to date on the latest info. Ford fixed the weakest part of the Taurus transmission in 2001 (I think it is the actuator piston, upgraded from aluminum to steel) and now they are reliable to at least 100k miles, and many exceed 150k miles.
It sure took them a long time to do it though. That trans has been in use since the Taurus was first introduced in 1986. The main problems started in 1986 and continued until it was revamped to hold up to the Taurus SHO and Continental V8. One of the worst chapters was the 1991 model year, when it would not maintain the line pressure needed for the trans to operate and last properly. Ford provided extra coverage for early failures for that model year. They were dropping like flies after spraying Raid.
That front clutch piston went through several revisions. A split piston was one of the most common failures for many years starting in 1986.
This same trans was used in Windstars where they failed even easier than they did in lighter Tauruses.
With as much flack as I faced with that transmission, I'm not sure if I could ever trust it.
