Originally Posted By: bdcardinal
you are supposed to replace the valve core on a stem mounted sensor. at least according to the ford class i took. strap mounted sensors do not require that.
Close, but not quite. You are SUPPOSED to pull the core, remove attaching nut, bump the stem assembly loose so that it falls loose inside tire(to avoid damage while breaking beads and removing tire from wheel), then breakdown and remove tire from wheel. When re-installing, a new hardware kit is required, consisting of a new rubber stem gasket, nut,metal washer, core, and cap. These replacement kits cost ME approx $12. wholesale. This is all according to "American Tire and Rim Manufacturers and Dealers Assoc".
As far as I concerned, this is total Bull [censored]. If tire techs take time to position stem 90deg from bead breaker no damage will occur. When removing and replacing beads on wheel, if area directly at stem is first pulled over dismount tool when removing and is tha last place to drop down when re-installing no damage will occur.
The large shops follow these guidelines to the letter and charge accordingly, mostly to cover their arse from improper tech actions in case of customer complaints, but also to generate a few bucks extra revenue.
Bob
By the way, if a new plain jane, rubber stem is required while fixing a flat or for any other reason other than when new tire is installed,, we still charge a buck.
