Well, it's been around 50k miles and a few cold winters since I threw some Amsoil Severe Gear 75w90 in the tranny and rear diff of my Subaru Forester. I must say I've loved every day of it. The Subaru 5-speed tends to be a little picky with slipperiness and good syncro function, and it just loved the Amsoil.
I started to drain out the old oil for some fresh stuff. I've only got the rear diff so far and will pump out the tranny fluid tomorrow. I say pump because the drain plug is apparently not going to budge, at least didn't last time at the auto shop.
I recently boiled the rear diff a little after a rally-x and having to run mismatched tires for a 50 mile drive home. God the center diff hated it, and the rear diff got a little too hot with the constant load. I got a lovely decel whine out of it too, not horrible but not going away either... Everything functions normally though, so probably just some roughness on the back sides of the teeth. They've never gotten used under load before, lol.
Wear was minimal on the rear diff, gears looked fine, very little metal on the magnet. The diff oil came out a bit black but didn't seem completely destroyed and probably still usable. I expect similar, well a little better, with the tranny fluid.
I auto-x, rally-x, and ice race the Forester a decent amount, and I make the 2.5L NA work hard not to mention the diffs. The Severe Gear has help up flawlessly and feels as good as it did the day I put it in a few years ago.
I'll see if I can get an oil analysis done on the tranny fluid. There's a local lubricants guy who handles a good portion of the Midwest's commercial needs. I'll probably chat with him tomorrow and ask about the procedure. I know he does it quite a bit for fleet vehicles and his own oils. I want to get my motor oil checked in 1k miles or so too. I've been running M1 0w40 year round, swapping probably a bit too often according to some threads here at around 3-4k miles, PureOne filter too. I wouldn't mind bummping that to 5k or longer if I could easily get away with it at zero side-effects. I just know I'd have to dump in at least half a quart or more if I was doing an extended drain interval. I've run 0w30 and 0w40 with very little difference in loss, so I'm not certain exactly where it goes. I've had the Forester since 26k and now has nearly 80k. It's behaved about the same always. I may try Amsoil 0w30 or 5w40 in the future, but that discussion is another forum section, lol. I'll get tranny oil impressions and an analysis up whenever I can get that done and back.
