With 50/50 blend of MTL and MT-90 I could go from 2nd gear to 5th if I was redlining it and 3rd to 5th as well. With this Walmart GL-5 semi-synthetic gear lube when I try to skip a gear it almost grinds you can tell the syncros are not fully synch-ing. If I shift fast it also shifts a bit rough I hate haveing to sloe my shifts down to the speed I would shift at in an 13 speed big rig!
