dnewton3
Staff member
Let's see, I'm doing the math in my head and I've come to the conclusion that one of two things will happen here.
1) You'll continue to get excellent peformance out of this current fill, and blaze past the " ... or one year ..." mentality because you only did 8k miles in 6-7 months, thereby presumably only attaining 15k miles in a year, and not near the limit of this product combination, seeking out the fiscal payout of your investment
or
2) You'll let conventional wisdom and peer/market/internal mental pressures get the better of you, and you'll dump it long before it's truly used up, thereby negating any true value to the AME/bypass and relying solely on the warm-n-fuzzy feeling that only hype and conjecture can provide.
Here's where the math comes in: You run the AME only for 1 year. You probably spent at least $6/qt plus the cost of the bypass filter element, plus the FF filter element. I'm going to rough this out at $85 for 12 months (which does NOT include the cost of the bypass system itself). The reality is it's probably a bit more, to be sure.
Or, you could do two 7.5k mile O/FCI's with any decent dino HDEO at $2.50 qt, plus a couple of $5 filters (from say, fleetfilter) for around $60 for the 12 months. You have to accept that it's very reasonable for a Dmax to go 7.5K miles on a dino-based OCI and get very good wear results. Plenty of UOA's here to prove that. So it's feasible to say that the wear protection will be basically the same with either plan.
And if wear is a wash, then only the fiscal attribute is left.
Only time will tell!
or
