I have posted about this engine several times but here goes again. 2000 Trooper, 70k, 3.5l DOHC engine. Uses a hair over 1qt of oil per 3k. On my Trooper forum the reason has been discussed ad infinitum and has been determined to be oil drain holes in the rings that are too small and too few in number. The oils stays on the pistons and "cooks", thereby gumming up the ring packs. Well I Auto-Rx'd the engine and in the rinse phase it started running better, power, response, etc. But then it started to go back to it's evil ways using oil, etc. Well my contention is that the 5w-30 Havoline cooked up on the rings after the Rx had cleaned them. A self exacerbating problem if you will. I plan on a 2nd A-Rx treatment but I have an idea. Would M1 0w-30 which is thin on start and at temp drain back better? It used less on M1 5w-30 than anything before. I went the thickening route (4 qt 10-30 1 qt 15-50) and it hated that. It drinks dino like Ted Kennedy drinks scotch so I dont like that approach but did it for the A-Rx. What does the collective wisdom of the board say?
