Originally Posted By: ethangsmith
I refilled the tank ....and he is going to put a new filter on it and drain, strain, and refill the fuel in the tank. That will probably help, but I'm sure there is still going to be some nasty stuff left in the tank.
I guess the key word here is "strain" if he would just put fresh fuel in, rather than the flushed and strained fuel you may be good to go.
What is the best injector cleaner-fuel additive that would dissolve that gel and not clog the fuel filter again? I know Lucas fuel injector cleaner is supposed to be real good.
Frankly I wouldn't put anything in at this point. Get good fresh fuel in, flush the lines, new filter - and start the car. Make sure it runs reasonably well for a few hundred miles - then hit it hard with a cocktail of cleaners. Good and strong. Some guys will call me a redneck in this department, but I sometimes mix the OTC fuel system cleaners mentioned here and put them in with only a few gallons of gas in the tank. Then drive for a bit to let the stuff work. Finally refill the tank and drive some more. Lastly do a strong 2X dose of Amsoil PI. Drive until near "E". Refill...drive that tank down. FINALLY - change the oil, oil filter and fuel filter. Your fuel system will be clean and worry free.
