I have a Fram car oil filter that failed. The metal perforated "sleeve" in the center of the filter (which holds the pleated filter media back) partially collapsed toward the center core of the filter. The failure appears to have allowed the oil to "bypass" the filter media. ( I haven't cut it open) The oil & filter had 4000 miles of use. The silicone anti-drain back valve, was also displaced. The filter was from a 1997 Toyota in excellent mechanical condition. I am wondering if the engine has been damaged, and what I should do with the defective Fram Tough Guard filter. Any suggestions? Have you ever heard of Fram (Honeywell) paying for engine damage because of a defective filter? Would an oil analysis be a good idea? I haven't changed the oil yet, I was just installing a new filter half way between a full synthetic oil changes. Thanks, Daryl
