Termalene Grease 2, water and wash resistant?
Charleston, SC
Has anyone ever used this grease. We use it in the Navy, and I am curious as to its properties, is it good, bad indeifferent and if it has anything equivelant on the outside available to consumers. The MSDS sheet is pretty blank, but the grease is a very sticky, very thick blueish-green and the 5 gallon can states zinc is in it.
metal to metal protection in water, for example. Heavy duty items.
I am trying to find out if it is a useable grease for vehicles, like bushings, ball joints etc. They throw allot of this away after doing jobs where its left over and unable to be turned back in, yet its good.
Termalene 2 is a NLGI 2,
Penetration worked 60 strokes ASTM D217 +280
Aluminum Complex
Viscosity ASTM D445 at 40C cSt 180
at 100C cSt 16.2
Viscosity ASTM D2161 at 100F SUS 950
at 210F SUS 84.7
Dropping Point, ASTM D2265 C 260
(F) (500)
Oxidation Stability ASTM D942
Pressure Drop@100 hrs, kPa 27.6(4)
Water Washout ASTM D1264
at 38C, loss, weight % .04
Reversibility Excellent
Former Sub guy here...(ET1/SS)
I run the stuff in everything on my 89 1 Ton GMC.
It has always worked great for me!
I bought the stuff on line awhile ago after seeing how well it worked.
