Originally Posted By: ls1mike
Lot of alarmest...
At any rate. If you want to change to the green stuff, get all the old out or it will gel up; however; it is not necessary.
The gasket problem is an issue, but not as many cars have it as you would believe.
In 2001 the 3800 got updated gaskets and intake which eliminates the problem. Direct bolt on for the older ones with the problem
I had a 98 Bonneville that I put 210,000 miles on I changed the coolant every 40,000 miles, which was the key to not having any problem.
The 3.1 was totally different.
Cars I have owned with Dex Cool
98 Bonneville 210,000 miles
2001 GTP 230,000 miles
04 Silverado 72,000 miles
98 Z28 120,000 miles
2001 Z28 52,000 miles
My current Trans Am and Equinox.
Just don't get scared, and don't be stupid about it. If you are really worried get the updated intake and gasket. Spend a saturday swapping it out and move on.
Or do a flush every 30,000 to 50,000 miles like you will end up doing with green stuff anyway.
Wrong. The gasket problem happens on EVERY SINGLE 3.1, 3.4, 3.8, 4.3, 5.0, 5.7, and 7.4 motor. Every single UOA posted here with these engines shows coolant in the oil if it has the factory gaskets.
The updated intake manifold came out with the Series III 3.8L in 2004, but people are still reporting gasket failures until about 2005.
So, to the original poster - if you aren't mechanically inclined, I'd purchase the Series III intake manifold and a Fel Pro problem solver intake manifold gasket set and just get it done. It will leak, GARUNTEED. Once it's fixed with these parts, the engine will be one of the most rock solid and reliable you could get. I'd have no issue continuing to use Dexcool, but I would flush and fill on a regular basis - say ever 30,000 to 50,000 miles.
One way to see if you actually have an internal leak is to get a UOA.
