Originally Posted By: Jimmy9190
Twentynine, my Dakota has the 3.9 liter v6.
I have the same spring-loaded type wrench that Bill has pictured, mine is made by Lisle Tools and I got it off a USA Tool truck. I got it when I was working at the Chrysler dealership. It works but is somewhat of a pain to use due to the angle at which my filter is mounted to the block. The cup type have been the easiest for me to remove the old filters and also to reinstall the new filters on my own engine.
I have a variety of oil filter pliers, metal band type oil filter wrenches and a number of cup type wrenches that don't fit my filter. I sometimes miss the days of seeing the Snap-On truck rolling up to the service bays. Talk about a kid in a candy store....
Yeah!!! 3.9L that's a 5.2L minus 2 cylinders. Had one in a 1998 1500 single cab pick up. No HP, no gas mileage, never broke down, but heck I was paying for an 8 cyl performance in MPG, with only 6 cyl. Swapped it in on my 2004 1500 quad cab, hemi, got a better tranny, lots more power, all for about the same or maybe even slightly better MPG.
Oil filter? You have the normal Dodge filter right? Fram number would be PH-16?
Jimmy I always used the cheap common metal strap wrench when needed. Nearest I can remember I never had a problem with filter removal. Filter installation- spin it on with my hand, go hand tight, then kinda gather up my grip strength and do a "Hulk" number on it, say like maybe another 1/4 turn. Never had one leak.
By the way let me explain "Hulk". I am a small guy 5'8", 165#. In the past ten years I have broken both arms (in seperate accidents), and my grip strength has been greatly compromised. Not nearly what the grip strength of a normal individual. So what is hand tight for me would not be nearly as tight for you.
Long story short, one of those el-cheapo metal strap wrenches would work pretty good for you. You won't be able to slap it on in any position. I think the truth of it is almost any wrench would work for you, it turns into what "feels" best in your hand.
