Hi folks. I hope all is well. I'll try not to make this the typical "what kind of oil should I use" thread.
After a ten year hiatus from Mini-Sprint racing, I will be returning to competition later this year. I have a bone stock 2007 Suzuki GSX-R 750 engine going into the car. I will use genuine Suzuki oil filters.
Ten years ago, I used Valvoline 20W-50 Racing Formula and changed it after every night of racing. This may have been a little extreme, but it made me happy and kept the engine alive for four unbelievable years without a rebuild.
Now, the Suzuki owner's manual I bought with the engine states to use 10W-40. I will be using both Amsoil Motorcycle Formula and/or Mobil 1 Racing Formula in this engine.
My questions are:
1. Can I get away with a little longer OCI's than I did 10 years ago? How long would you go?
2. Would you stick with the recommended viscosity of 10W-40, or should I go to 20W-50?
Keep in mind that while installed in a Mini Sprint, this engine will be run full throttle for as much as five minutes at a time. Car weight is about 725 pounds, so that is about 300 pounds more than the engine would have to haul around if it remained in the original motorcycle.
Looking forward to your expert opinions!
My questions are:
