I did a brake job on a 06 Corolla with 37,501 miles over the weekend. I noticed that the left front brake caliper's dust boot was slightly distorted. By that I mean a 2-3mm section of the dust boot was sticking out very slightly once the piston was fully retracted. The dust boot wasn't cracked, but a slight edge of it was sticking out and covering the lip of the piston. It appeared as though once the piston was pushed out, the dust boot would pop back into place.
The pads that I removed from that caliper looked like this:
2mm
1.5mm
The pads from the right front caliper, which did not have any piston seal problems, the pads looked like this:
3.5mm
2.5mm
Not as bad, but still worn out. The difference in pad wear is no more than 2mm. However, BOTH rotors were badly grooved, even on the right front caliper for some reason. The rotors looked like this:
When you run your fingernails across the rotor surface, you can definitely feel the grooves.
I went ahead and installed new pads and rotors. I'm guessing that while the piston seal may not be in great shape on the left front caliper, it isn't bad enough to warrant replacement. There's only about a 2mm difference in pad wear over 37.5k. The driver of this vehicle is on track to wear out pads every 20-25k (she bought this car used).
What do you guys think? What should I do? Should I just tell her to not worry about it in the meantime and just replace both calipers at the next brake job? Or is it not a concern at all?
2mm
1.5mm
3.5mm
2.5mm
