I got new plugs and wires and cap and rotor for this beater. I pulled the first spark plug wire (this has them down the tube) and my cheap spark plug socket could not lock on the hex of the plug so I decided it was a cheap spark plug socket and bought a better one. Again pulled the wire and the better socket fit fine and removed the plug with no problem. Went on to the next plug and pulled it and had same problem where socket could not lock on to the hex of the plug. Then I looked at the two wires and realized there was a 3/4" boot at the bottom of the plastic section of the wire that had stuck on the plug and the plastic section (of the wire) just pulled off this boot. No matter how hard one pushes you cannot get the socket to lock of the hex of the plug.
So how does one get these stuck boots off that are 5" down the tube. Its hot outside (engine is cool) about 85-90F.
So, maybe when its cooler the boot will come off with the plastic section. The plastic section does have 2 ridges to catch the boot. Or maybe get some caulk or rubber cement and glue the plastic section to the boot, wait till dry and remove. Find something like a long pick that I can stick down the hold and grab the boot.
The new wires have some glue visable glueing the boot to the plastic section.
Note to self - do not buy wires where the boots are not glued to the wires.
