Well, before I take my car in ('95 Ford Aspire) to fix the front wheel bearings I thought I'd give it one more try myself. I can't get the front hub nut loose! I'm using a 30mm socket on a 1/2" breaker bar w/ ~a 3 inch cheater pipe! It wont budge! Maybe it got so hot the thing welded iteslf... anyway, any other suggestions? I could try barrowing an impact wrench from someone. I'm not sure if using my angle grinder w/ cutoff wheel is the way to go. Any suggestions? thanks....
