Originally Posted By: Cooper
I recently purchased a 2003 Honda Odyssey with 64,000 miles on the clock. The ATF needs to be changed out. Amsoil says it is okay for Honda Z-1. How does the Amsoil stack up compared to the Z-1? Should I flush the system with Amsoil, or is the Z-1 the way to go? I also plan on changing out the ATF filter as listed in another post.
Amsoil stacks up great compared to Z-1.
Change the filter. I would then flush it really well with a low cost ATF of your choice, use Dexron, Z-1, whatever. We are getting all the Honda metal and old fluid out of there. Then immediately flush that really well with Amsoil ATF. I have come to the conclusion with these early Ody trannies, a drain and fill is pointless, if not worse as it builds false security.
If you choose Amsoil ATF, you want 100% Amsoil ATF.
