My 196x Farmall 140 tractor discharges its battery, over a few of days, when the ignition is off. There really isn't much to the whole electrical system, a starter, an internally regulated Delco alternator, a keyed ignition switch and a starter button. The battery tests good using a load tester and the alternator puts out 14.4 volts. If I remove the battery cable when the tractor ignition is off, the battery does not drain. Any suggestions how to find the slight battery drain? Can an alternator defect cause a drain, perhaps in its diode pack?
