Hello folks, wanted to share my first UOA with you and maybe see what you have to say about its interpretation. Thanks!
Keep in mind that I replaced the filter at the beginning of this UOA, and my sample was taken closer to the end of the drain, because I'm kinda retarded and pulled the drain plug before I was ready to harvest the sample... but wear levels are still a bit startling...not sure what that's about, but we will see what the 0w-40 I'm now running does.
MAKE/MODEL: Subaru Impreza WRX
FUEL TYPE: Gasoline
ADDITIONAL INFO:
OIL TYPE & GRADE:0w-30 Mobil 1
OIL USE INTERVAL: 3446
"Both wear and silicon were above average in your first oil sample. Most engines have matured by 20,000 miles but that may not be the case for your 2.5L. If we don't see a marked improvement in both wear and silicon next time we may suggest having a look at your air filter. Or you may want to look at it now. It would be odd for it to be dirty in such a new engine but it's possible. The trace of fuel isn't a problem and no other harmful contaminants were found. The TBN read 3.6 showing some active additive left. Universal averages are based on 4400 miles."
Substance/PPM/Universal Averages
ALUMINUM/3/3
CHROMIUM/1/1
IRON/14/7
COPPER/36/5 (Crickey!)
LEAD/5/4
TIN/0/0
MOLYBDENUM/96/70 (Would be interesting to see what this looks like at 4400mi).
NICKEL/1/0
Manganese/1/4
SILVER/0/0
TITANIUM/0/0
POTASSIUM/1/1
BORON/46/44
SILICON/19/12
SODIUM/5/9
CALCIUM/2328/2219
MAGNESIUM/12/115 (Not sure what this means...).
PHOSPHORUS/643/704 (Low phosphorus additive content?).
ZINC/797/839 (Low zinc package too...).
BARIUM/0/0
Value/Value should be:
SUS Visc @210 57.1/55-60 (Thick enough it seems).
cSt @ 100C 9.40/8.8-10.5 (Still looking ok).
Flashpoint in F 360/>360 (Oh dear...).
Fuel % "TR"/ Antifreeze 0%
Water 0%
Insolubles 0.3%/ TBN 3.6
On the whole not a great report...I may try this once more and make sure I don't FUBAR the sample, but then again I might not risk it... We'll see what a nominally thicker oil does.
The flashpoint in particular bothers me...not sure how it could have good kinematic viscosity but still have a low flash point like that. Perhaps my high wear was due to this fact.
FUEL TYPE: Gasoline
ADDITIONAL INFO:
ALUMINUM/3/3
CHROMIUM/1/1
IRON/14/7
LEAD/5/4
TIN/0/0
NICKEL/1/0
Manganese/1/4
SILVER/0/0
TITANIUM/0/0
POTASSIUM/1/1
BORON/46/44
SILICON/19/12
SODIUM/5/9
CALCIUM/2328/2219
BARIUM/0/0
Water 0%
