Ok, I'm sure hoping this is easier than changing out the trans fluid. My 2000 explorer has 114K and I just want something to do tomorrow. Any words of wisdom before I try another automotive "quick fix" that ends up taking 5 hours and 3 trips to NAPA? I'm guessing I just pull the bolts holding the cover, clean off the gasket, let fluid drain, reinstall gasket and cover, replace fluid. Sounds easy........
